Thread: How often do you change the seal in your pool light?
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    It looks like the seal failed in our Pentair underwater pool light and it needs to be replaced. We have had the pool 8 years and I never thought to replace the seal. Is there a recommended time frame to replace the seal in an underwater pool light? I'd rather pay $15 for a new seal, than $500 for a new light but I wasn't sure how often it should be done.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: How often do you change the seal in your pool light?
    Usually only if you need to change the bulb.
    Like the old saying goes "if it aint broke, don't fix it."
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Johnl's Avatar
    May 2008
    88
    Quote Originally Posted by ps0303
    The new light I ordered is LED, so it will likely need a seal change before the light ever burns out. Given the first seal failed in 8 years, I'll probably have to consider changing it every 5 - 6 years to be safe (and not spend another $500 changing the whole light fixture).
    23K Gunite IG Pool
    Aquarite 40k SWG
    Polaris 360
