Results 1 to 9 of 9
Thread: PH Accuracy with Shock Level Chlorine
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    We just finished the shock process a couple days ago and FC is 17, CC 0, PH 7.3, TA 130, CYA 60.
    I read that when chlorine is high that PH testing is inaccurate. Just wondering if that's true or not, and should I be adding Borax or Soda Ash to increase the PH, or should I wait for chlorine to go down to normal range? Also, my TA is high so not sure if I should adjust that now, or wait on doing that.
    Thanks!
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    38,371
    Re: PH Accuracy with Shock Level Chlorine
    It is true, pH is artificially high when FC greater than 10ppm
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Apr 2009
    S.E. MI
    570
    Thanks so much for the replies and the link. This morning FC is 14.5, CC 0, and CYA 60 (was late for work so I haven't done a full test yet). PH is reading at 7.4. Since FC is higher than 10, I wonder if my PH is really lower than it's reading.
    Once the chlorine comes down to normal range, I'll be turning on the SWG, which will probably make the PH go up anyway.
    Would you guys suggest just leaving PH alone for now?
    Yes, leave it alone for now. But do retest PH as soon as the FC level comes down.
    Apr 2009
    S.E. MI
    570
    Ok, thanks Jason
    I do have one last question, since it might be a few days to get the chlorine down, would it be ok to run the heater while the FC is still high? I really want to heat up the pool. Water temp this morning was only 70, and it's not supposed to be very hot here for the next week or so. I'd have to run the heater for a good 10 hours or so and I'm not sure if the high chlorine might be bad for it. I'd imagine short term it wouldn't be, but just want to make sure.
    bmann71's Avatar
    Aug 2007
    Washington, Indiana
    55
    I may be totally screwed up but I'm pretty sure your water is going thru your heater regardless if the heater is on or not so I'm not sure what a high FC reading would matter.
    Ponduke
    20,000 gal/ Fiberglass IG/ Sta-rite s7m120 cartridge filter/Sta-rite SR400NA 400,000 btu heater/Polaris 360 Cleaner/K-2006 Test Kit
    poolcalculator
    Pool School
    38,371
    Running the heater is fine.
    Apr 2009
    S.E. MI
    570
    Thanks, Jason! Bmann71, good point! I was wondering the same thing but since I know zip about heaters, I figured there must be more to it
