Thread: Chlorine strength question
    Jul 2011
    Northern MN
    21
    Quick question: I have some liquid chlorine that says "12.5% sodium hydrochlorate, 87.5% other ingredients, and 15% available chlorine". As far as the pool calculator, is this 12.5% or 15%?
    Thanks.
    24-ft round Radiant AG, fully in the ground, 14,500 gal
    Sand filter, 1.5 HP pump, vinyl liner
    9 months of winter, 3 months of tough skating!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Chlorine strength question
    Use 12.5%. Their calculation of Available Chlorine has to be wrong, but odds are they aren't at 15% strength. If you find you are getting a higher FC than you expected, then you can always use 15%.
