Thread: Deck Privacy
    Jun 2008
    NJ
    12
    Deck Privacy
    Looking for ideas for the some privacy while on the pool deck.
    Have some trees on the right side but nothing on the left.
    I dont want the great wall of China but something that looks good and does the job.
    5100 gal Above Ground Intex Pool with cheap filter and pump
    TF-100 Test Kit
    Feb 2008
    Denton, TX
    5,061
    Re: Deck Privacy
    Since it's an ABG pool, it's raised up and that makes it tougher.
    I'm not sure what grows up there. Down in Texas, we can use oleander and red wax leaf shrubs since they are hardy and can get really occlusive if you allow them to. First, I would look into fencing. Then, I'd check out things you can plant.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Deck Privacy
    I don't know what they were, but I saw a pool here in town a month or two ago where the back side of the pool was blocked off with a grove of small wispy trees that stood 15-20 feet high and were bushy all the way to the ground spaced about 2 feet apart and staggered 2 or 3 trees deep. Perhaps you could ask on a landscaping forum like gardenweb for some advice of identification help, they made me think of some sort of willow, but I really don't have a clue what they were.
    Ike
    ps After a bit of searching I think what they had was Sky Pencil Holly, even though most listings show the height at 8-10 feet that seems to be average height at 10 years of age with it being available already at 5-6 feet and a growth rate of up to a foot per year depending on climate. The house where I saw it was probably built in the mid 1990's, pool may be a couple of years newer. So 15-20 feet at 15 or so years in Louisiana may be about right if planted at about 6 ft height.
    Jun 2008
    NJ
    12
    Re: Deck Privacy
    Thanks!
    I'm also looking at a few things on the deck that a friend mentioned.
    He suggested adding to the railings on the sides.
    I'm looking for the best solution money wise and time wise.
    TF-100 Test Kit
