Thread: after pool opening, de and debris in pool return
    Hi,
    I replaced my filter last year. I had the same company open the pool. While opening the pool, they made a couple of mistakes which I figured out. Yesterday I vacuumed my pool (to waste) for the first time this year. I noticed small debris coming out of the returns. afterwards I backwashed the pool and DE started coming out of the return jets. This morning i had to vacuum again, I noticed small debris again. A little afraid to backwash.
    my guess is there's a hole in the one of the filter panels or they were installed incorrectly. thoughts?
    tia
    37x20, 28,300 gallon gunite, irregularly shaped, hayward 1.5 super pump, hayward 4820 DE filter, northeast geo
    30,424
    Re: after pool opening, de and debris in pool return
    What kind of filter do you have? Now would be a good time to enter that info in your sig so you don't have to type it every time.
    thanks, it's a hayward 4820.
    I started experiencing the same problem late last year. After noticing a few small tears in sime grids, I replaced all of them just this weekend when I opened the pool. The water is now clear, except for some sediment at the bottom. When I backwash and re-load with DE, white clouds come out of the return jets. What was your issue/remedy?
    ~18K gal, IG gunite, Jandy 1.5 HP pump, Jandy DEL48 filter, Jandy Lite2 400K BTU natural gas heater, Polaris Vac-Sweep 280 w/Century 3/4 HP motor
