Results 1 to 7 of 7
Thread: using an extension cord with an electric robot?
    hi,
    we don't have an outlet near the pool, does anyone use an extension cord with their pool cleaner?
    thanks,
    jd
    37x20, 28,300 gallon gunite, irregularly shaped, hayward 1.5 super pump, hayward 4820 DE filter, northeast geo
    30,432
    Re: using an extension cord with an electric robot?
    I don't use one but it seems harmless enough just taking normal precautions so it doesn't fall in the water.
    Feb 2008
    Denton, TX
    5,061
    I think that as long as it is a 3 prong outdoor extension cord and it isn't super duper freaky long, you should be ok.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I think you'd be wise to tie the extension cord to a post somewhere so there's no way the plugged together ends can be pulled into the pool accidentally.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also make sure it is plugged into a GFCI protected outlet. This has been required for outdoor outlets for a number of years, but if your house is more than 10-15 years old you may not have them.
    Ike
    Mar 2013
    CT
    353
    I use one with my Hayward Tiger Shark. One thing I would add is make sure to use at least at 12 gauge cord. 10 Gauge would be better. The lower the gauge, the thicker the cord and the less voltage drop you will have. And get one that is only as long as you need it. The shorter the better. Again, less drop in power.
    I found the service manual for my robot on line. Many of the trouble shooting issues involve not enough voltage getting to the unit due to the use of a cheap, thin extension cord that wasn't supplying enough voltage.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I used an ext chord on a shop vac while sucking up leaves around the pool. The vac accidentally rolled into the pool... blew the ground fault device instantly. I let the vac dry out and still functions! Don't think it's be swimming with a robot attached to an ext chord though.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
