Thread: Final Payment due - leaky valve
    Feb 2013
    Metro St. Louis
    93
    Our pool build is finished, and the PB is coming out this week to review and collect final payment. However, I noticed today that one of the return ball valves leaks when I "partially close" it. When we run the pressure side cleaner, I partial close the returns to divert more pressure to the cleaner. Today it started a drip when partially closed. It does not seem to leak when fully open or fully closed.
    After researching here, seems my "red" valves are some cheap valves from China. I think if I press the PB, he would replace for free, since it should not leak, unless he says "don't partial close".
    On the other hand, I think replacing with Jandy Neverlube type valves would be a great upgrade. I believe I can do that myself and not even bother with the PB...as we are so ready for "construction" folks to be gone
    From my photo, the top valve (returns) is the problem. If I replace with Jandy's myself, I would do the "cleaner" one as well...so my wife can more easily open/close it.
    Question, since the current valves are butted up against the 90 degree elbow...what is the best method to replace? Should I dig down and remove the elbow as well...and use a coupling to attach a new elbow/valve section?
    Paul
    Sterling Steel IGP lagoon 21' x 35' w/6' deep end, Pentair 5g LED lights (x2), Pentair Landscape LED light, Pentiar IntelliFlo VS pump, Pentair 420 Cartridge filter, Pentair IC20, 4 gas Tiki Torches, LoopLoc Ultra Loc II, Deck Jets(x3), Raised Planter Bed with 3 Pentair bronze sheer decents, AquaBot Breeze 4WD, Pentair Legend II
    Mar 2010
    Spring, TX
    1,082
    Re: Final Payment due - leaky valve
    If it was me I would make them fix anything wrong before the final payment.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Feb 2013
    Metro St. Louis
    93
    I typically would (and may still)...but they will just replace with another cheap valve I am sure. Guess I could provide the Jandy valve and still have them replace. My wife is so ready for them to be done...and the fact that it does not leak when opened...I would almost prefer to do myself in the next month or so. I learned before that some of these guys that come out fix one thing and break 2 more things.
    Anyone have tips on how best to replace if DIY?
    Paul
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Looking at a glance, it seems as though you would have to dig down and re-plumb upwards.
    Better question: Can you tell precisely where in the valve the leak is coming from? Ours was coming from the red disk on the top of the handle. I popped out the red disk, put a 2" square piece of heavy plastic bag (from pool salt) across the top, and pressed the red disk back on. Magically, it created a seal. Eventually, I will replace it with a good quality valve, but am not ready to start digging! We just plumbed in a new filter.
    But YOU'VE got all NEW equipment, and it SHOULD be handled by the PB. If you supply the valve(s), he might do it, but I wouldn't expect him to change out the other one (labelled cleaner) at no charge.
    Good luck, and enjoy your pool.
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
    Feb 2013
    Metro St. Louis
    93
    Thanks. I will look more closely next time I partially close it. At a glance, it looked like it was down lower where the red handle meets the pvc. Thanks for the tip!
    Paul
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yeah, looks like a nightmare to repair, whole thing would probably have to be cut out and replaced, why pool builders seem to always glue in slip on fittings like this is beyond me, for an extra $30-$40 they could have added screw together unions on all feed pipes and threaded PVC valves with threaded connectors.
