Results 1 to 8 of 8
Thread: filter sizing for a 55k filter
    Hello,
    Need some help sizing a filter for a large 55k pool. The pool has two skimmers and one side return, no main drain. All plumbing is 1.5". Currently this is feeding into a new hayward 1.5hp super pump. The current filter is an old 72 sq ft DE filter. Would like to switch to sand and was suggesting a hayward 310S to him. It seemed like the pump would not have sufficient flow for the 316. Would this be a good fit? If not, can someone make some recommendations?
    Matt
    "The Lake" - 42'x18'x52" Vinyl AGP @ approx 23,000 gal.
    500lb Hayward S310T Sand Filter and Waterway FC125 Cartridge Filter
    2hp - 2 speed pump (110v, 14.4a high, 4.4a low) TF-100 Test Kit
    30,414
    Re: filter sizing for a 55k filter
    Welcome to the forum. I would say it is not a good fit. It's not big enough. You will get a LOT more filtration and time between backwashes with a larger filter.
    My 42k pool has a sand filter with 925 lbs of sand.....the 310 has 500 lbs of sand.
    Is that an uprated 1.5 HP pump or a full-rated?
    May 2009
    Youngsville NC
    395
    My 19,000 gallon inground pool is using a sand filter with 300 pounds of sand, and I consider that a pretty good fit FOR MY POOL, not to say that bigger wouldn't be better. For your's, I would consider that 300 pound filter to be undersized. You may also want to consider a larger pump.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, rnpilot
    As others have said, that is a large pool. In terms of residential filters, they stop at about 7 sq. ft. which we would say is a minimum for a 38000 pool. Above that you need to go with multiple filters or a much larger commercial filter solution.
    As duraleigh said, the uprated 1.5 hp superpump may not be able to create enough flow to backwash a 7 sq. ft. filter. In addition, the restrictive plumbing (how many runs of 1.5" suction and return?) size may limit how much flow you can get even with a bigger pump...which will limit your filter size.
    Thanks for the replies, I have a 22k pool and my filter is 300lbs. Was thinking 500 would be undersized but there is only 2 1.5 returns coming in to the filter. Filter that is there now is DE. It's adequate but aging and needs replacement. Was hoping to avoid going back to DE
    To elaborate on above post, there are two 1.5 suction and one 1.5 return currently filtered by a 72 sq ft DE filter. Based on replies it doesn't seem like sand is a viable option? Would DE or cartridge work better in this scenario. Pool is 30+ years old and has been ok. Trying to avoid the maintenance of DE. Thanks again.
    Matt
    30,414
    Is your pool 22k or 55k???
    I have a 22K pool, but am refering to a friends 55k pool.
