Thread: Question on piping a heater
    I'm piping in the water pipes for my Hayward natural gas heater. The diagrams in the installation manual show the inlet and outlet pipes coming out the side of the heater and doing a 90 degree turn downwards. But, it never actually says that it's necessary for them to point downwards. Is there any reason why I can't have them come out the side of the heater and do a 90 degree turn upwards instead? I wasn't sure if they have it going downwards to prevent water from reentering the heater after the pump was shutoff?
    Thanks
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Question on piping a heater
    Mine comes straight out (same heater) so I don't think it matters. Also unless you have a vacuum release valve somewhere in the plumbing, when the pump shuts off water will not flow and remains in the heater at all times.
    Mark
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    It doesn't matter if it does a loop do lou as it comes out of the heater. If you have an inline chlorinator that you put tabs in, make sure you put a check valve on the line returning to the pool. This will prevent the chlorinator from back feeding into the heater.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Thanks everyone.
    I've got a salt water system. Is a check valve needed there?
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Not as necessary on a salt system.
    Paul
