Okay, just checked my chlorine after a couple hours and FC was 8. Does it take a little more time for FC to get to 12 or do I go ahead and add more bleach per the pool calculator.
Also on the laminated instructions for the TF-100, step 3 for the Chlorine Drop Test says and I qoute "Next, carefully add the R-0871 solution one drop at a time, swirling as you drop. Count each drop until the solution turns back to clear. Multiply the number of drops you added x0.5 (ie 14 drops x .05= 7ppm) Record this as Free Clorine (FC)."
Now on step 4 it says "To test for Combined Chloramines (CC), add 5 drops of R-0003 to the now clear solution and swirl. If it remains clear, you have no CC's. If it returns to pink, add R-0871 as before, counting and swirling between each drop. Once the solution returns clear, multiply the added drops x 0.5 again. This is your CC reading. Record it."
Are the numbers 0.5 and .05 a typo and if it is which is which?
