Thread: Phos-free
    Sep 2011
    Atlanta Ga
    310
    Phos-free
    What is in it? What good does it do? What harm does it do?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Re: Can Phos-free be used in lieu of shock?
    Phos-Free removes phosphates from the water. If you get the phosphate level low enough, algae usually can't grow as it has nothing to eat. However there are forms of phosphate that are not removed by phos-free, so that is not guaranteed. Phosphate remover tends to cloud up the water. Ideally this clears up quickly, but for some people it can stay cloudy for days. Also, some areas add phosphates to the tap water, which can cause phosphate levels so high that getting the phosphate level low enough is impractical.
    Of course algae isn't the only reason you need chlorine, as bacteria and viruses can do just fine even at extremely low phosphate levels. So you have to have chlorine anyway. If you maintain appropriate levels of chlorine no algae can grow in the water, with or without phosphates. You have to have chlorine anyway, and chlorine alone is sufficient, so why waste time and money on phosphate remover?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Phos-free
    Quote Originally Posted by TomAtlanta
    Here's just one lengthy thread about phosphates: phosphates-can-be-a-serious-problem-t16805.html?hilit=phosphates
    The search box is your friend. If you look for others using the search box, you might want to limit it to thread titles only to keep the number of posts to only a few hundred.
    Sep 2011
    Atlanta Ga
    310
    Re: Phos-free
    Thanks for the link, and the suggestion on how to do a search. I have also been using google to search, adding troublefree pool to whatever I am searching for.
    27000 gallons
    Pool built in 1971.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Phos-free
    If you want to know whats in it, its Lanthanum, and the first element in the Lanthanide series of "rare-earth" metals, even though Lanthanum isn't rare.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Phos-free
    And what it does it to precipitate lanthanum phosphate which is why it clouds pool water unless a clarifier is used (PhosFree supposedly has a clarifier in it for that reason). The precipitate will then get caught in the filter and have to be backwashed or cleaned. Lanthanum chemicals (usually lanthanum chloride or lanthanum carbonate) are expensive so if you have a lot of phosphate in the pool water, it can get expensive to remove.
