Thread: How much to raise my TA...
    Shelley N's Avatar
    Denver, Colorado
    199
    FC 4.5
    TA 50
    CAL 70
    PH 7.5
    CYA 20-25
    I use Clorox
    Above ground vinyl pool
    PH drops .2 every other day so I've needed to add Borax to get it up to 7.5-7.6. I'm thinking the TA is too low to keep it stable, but I want to do this right and not overdo it as I like adding Borax much better than acid! Should I get the PH to 7.6 then add enough baking soda to get the TA up to 60? 70? 80?
    I know my CYA is a little low, but I was trying an experiment to see if CYA is why I'm so very dry when getting out of the pool. After just doing tests, my hands feel like sandpaper, so my guess is it's not the CYA....
    Shelley
    Denver, CO
    30,408
    Re: How much to raise my TA...
    VERY unusual for a pool to drop in pH. How are you chlorinating?
    Butterfly's Avatar
    South Carolina
    10,045
    Are you using anything other than Clorox? .... like maybe some trichlor pucks/tabs?
    You're done SLAMing when:
    Shelley N's Avatar
    Denver, Colorado
    199
    Nope, just household bleach. I had a self draining cover this winter and our soils (dust) is very alkaline though. Never used pucks. It drops every year, just not as fast as this. My alk hasn't been quiet this low on opening though.
    Shelley
    Denver, CO
