Thread: Intex 18 x9 retangle Skimmer
    May 2013
    Chandler Arizona
    78
    I have the 18 x 9 rectangle intex ultra frame came with 1200 gph sand filter. Has anyone used the intex surface skimmer with this sand filter? The skimmer says 1500 gph minimum. Probably wont work with this sand filter?
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    Jan 2013
    Aruba
    229
    Re: Intex 18 x9 retangle Skimmer
    I have used the surface skimmer with the small 1000gph cartridge filter, and it had it work pretty well
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
