Thread: Above/Inground pool wall rusting
    Hi,
    I've been browsing the site for a while and it has saved me a few times. I finally have an issue I need some more help on though.
    House we bought has a 24' 48" deep above ground pool. Its semi buried in a hill. The one side is about a foot above the ground, the other is not in the ground at all. When I took the cover off this winter the liner had a nice large rip in it. Ordered a new liner and started removing the old one today when i noticed a 1"x1" hole in the side of the pool. The hole is from rust. It appears someone had patched the liner previously in that area and did not do the best job so water was seeping out.
    Pool guy said he would put a new piece of metal over the area and silicone it in. Wife thought of trying to get a new wall skin, but I'm not to sure how that would work.
    What are my options?
    Thank you so much!!!
    5K gal, Intex 15' x 48", Intex sand filter pump, 1/2 HP, model SF15110, Hayward AquaRay Flapper Disk Cleaner, BBB method, Taylor K-2006 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Above/Inground pool wall rusting
    As long as the rust is just where the hole is I think the pool guy approach should work. I would clean up the area and apply some rustoleum to stop the corrosion. I have heard of others doing that on here. Make sure you protect the liner with plenty of duct tape over the patch.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Folks have patched pool walls with sheet metal. Some use screws others have used rivits to hold the patch in place. I don't know how well silicone would hold over time. Which ever way you do it cover the edges with duct tape so no sharp edges are exposed.
    Love TFP? Become a
    TFP Supporter!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    zea has a good point...when I said "I have seen others on here do that", I meant patching with piece of sheet metal not the silicone as the attachment method. I could see silicone working, but I might use rivets or maybe something like jbweld instead.
    Thank you guys so much! I was a little worried what I was going to do with the pool.
