Thread: Replace Hayward Dial a flo 733
    May 2013
    NJ
    114
    I am redoing some of my 25 year old pool plumbing and find it necessary to replace my Hayward 733 Dial a Flo 3 way diverter valve. Of course the first thing I find out is that the same exact one is no longer available. Are there other good valves ,such as Jandy, that do the exact same thing. My current valve has a 4 settings: full port 1 (bottom drain), full port 2 (skimmer), 1/2 each port and off. The replacement valves I have been looking at seem to have port 1, port 2, or both (wide open I think). I am not sure the replacements have 1/2 port 1 and 1/2 port 2 as does the Hayward. Or at least I think the Hayward does by looking at the label on the valve. I haven't opened it up to verify it is actually opening each port 1/2 way. Also I read another post somewhere where someone complained the off setting on replacements was not a total off like on the Hayward. Any thoughts?
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
    Re: Replace Hayward Dial a flo 733
    I'm no expert on this at all, but the diverter valves I've seen are continuously variable from port 1 open to both open to the port 2 open. I haven't seen one that turned both off. If you needed this add a ball valve on the supply port.
    No pool yet. Installing a partially buried Swim-n-Play 15 x 30 above ground.
