Thread: Dolphins diagnostic won't turn on
    Hey folks,
    My 7 year old dolphin diagnostic just started giving me some problems. One day it wouldn't start its cleaning cycle after being turned on. Power supply light was on and cord was connected well. Couple of days later the problem just magically fixed itself. Fast forward a month and the problem is back. Only this time it's not fixing itself.
    I'm assuming its just dead and there's nothing I can do about it, but before I go out and spend $1,000 on a new robot, I wanted to double check. Any ideas? Maybe a way to reset some board inside of it or something? Maybe a cheap part to replace? Again, the power supply light does turn on. I unplugged it for a couple of days and still nothing.
    Thanks
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    Feb 2008
    Denton, TX
    5,061
    Re: Dolphins diagnostic won't turn on
    If it won't work and then all of the sudden, after a couple of days, it seems to work again for a bit, then you most likely have water getting in somewhere that it shouldn't be.
