Thread: Wire help for a 2 speed Pentair SuperFlo
    I am upgrading from a Pentair 1 speed 3/4 hp to a 2 speed 1 hp Pentair SuperFlo.
    I have 3 wires coming out of my timer. 2 hot and 1 green ground.
    How should I wire this?
    Thanks for you help!
    15k gal +/-
    IG Plaster
    Cartridge Hayward 90g
    1HP Pentair Superflo 2 speed
    Old Pool new Diamonbright 2 years ago
    Re: Wire help for a 2 speed Pentair SuperFlo
    If your pump came with a speed switch on the pump, which it looks like your did, you simply wire as in the diagram on the pump with the speed switch. One hot wire to common, one hot wire to the middle wire from the switch, and ground to the green chassis screw.
    Easy as it sounded. TY for the help!
    15k gal +/-
    IG Plaster
