Thread: we seem to be high on one sid
    May 2013
    Arizona
    112
    Git pool up looks like weve got an inch higher on one side weve put about two inches of water in to smooth the bottom. Is this is a huge problem guys? What do we do
    Re: we seem to be high on one sid
    If you are only one inch out of level you will be alright. If it is more than an inch you should take down the pool and re-level the ground.
    What type of pool? If Frame-style intex, be sure to put pavers under the legs before filling.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    More water addition = more weight = more probable sinking. Keep a close eye on it.
    In all practicality, you're not higher on one side...........you're LOWER on one side!
