Results 1 to 8 of 8
Thread: How to connect two intex pumps to use at the same time?
    Hi,
    I have a 12x36 intex frame pool. For the first year, I used the pump that came with the pool. Not sure exactly but I believe it was less than 1000 gal/hr. Not as good as I wanted but I tested and adjusted my water daily and never had water issues. After that a friend who had a bigger intex and got a new pool gave me their pump. It is either 1000 or 1500 gal/hr. Same hose fittings so I know it was not a lot bigger than my first one. It did a better job but I still would like even better.
    My goal is to upgrade the pump to either a much larger cartridge filter or possibly an intex sand filter, but it is not in the budget right now though I am closely monitoring Craigslist for a used one.
    I remember a few people on here hooking two intex pumps together to run at the same time. Is this a good idea? If so, what would I need to connect them? Completely hardware-and-diy-challenged here so if anyone knows links to pics or anything that would be great, though any thoughts or advice is appreciated!
    Laura
    Re: How to connect two intex pumps to use at the same time?
    I recommend just using the larger pump alone. You don't really want to use two pumps at the same time unless they are identical, and even then the extra work of having two pumps to keep working tends to make it not worth the effort.
    When i had Intex cartridge style filter, i had some luck rubberbanding a knee higgh nylon and/or cotton sock over the return jet inside the pool. It caught some stuff that passed through the filter.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Not a good idea to run two pumps in series. Creates more problems than it solves.
    Since you do use craigslist, post a wanted add for the type of pump you are looking for. At least it worked for me.....
    I'd bet the pump that came with your pool was a 580GPH. Common to the smaller pools. The 1000GPH is a definite step in the right direction.
    Amazon and Ebay have the 2500gph cartridge filter pump sets(with hoses and valves) for under $100. I wouldn't waste money on a used pump.
    1) 7500 Gallon Free Form Gunite Pool / 800 Gallon Gunite Spa
    2) EasyTouch 8 Automation / IC20 Intellichlor
    3) Intelliflo VS Pump for pool and water features - Cartridge and DE Filter / 2 Speed Pentair Pump for Spa and Cartridge Filter
    Aug 2011
    Virginia Beach
    295
    Drape the hoses for the second filter over the side. Set them to make a whirlpool if you can, this will help bring the dirt to the center of the pool, making it easier to clean up. I wouldn't waste time or energy trying to tie them together. You'll have better results and more versatility keeping them separated.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Glad I asked...Thanks everyone! The bigger pump is fine for now, and I'll just keep the small one for backup just in case. Just started filling today, yay!
    Jan 2013
    Aruba
    229
    I have been using the small 580gph and the 1000 gph on the 15x48"
    On the thru the wall skimmer i have been using the 1000 gph,and the 580gph on the pool inlet and outlet.
    The return of the 1000gph i turned in too a fountain
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
