Results 1 to 9 of 9
Thread: k-2006 no spoon for reactant powder - Found it NM
    May 2013
    Twin Lakes Wi
    9
    Found it, same color as kit, blended in. Thx to those that replied.
    Thanks
    Phil
    24Ft Round 16k Gal, AG, Hayward DE 50AC, 2.0HP Pump, 2004.
    Feb 2008
    Denton, TX
    5,061
    Re: k-2006 no spoon for reactant powder
    Take a plastic straw like a drinking straw, cut it short, and cut one end at a 45 degree angle. Then you can use it to scoop.
    The spoon is tiny and the amount needed is not precise. You want enough to turn it bright pink. Using too much is not a big deal but is a huge waste of that powder. The spoon that comes with it is way less than 1/8 tsp, it appears to me. For a household substitute, I'd think you could use a butter knife and lift out less than a pea-size mound (like 1/2 a pea) and put it in the water. If it does not turn pink, you don't have enough but can't be far off. TFTest Kits (you can find links to that throughout this forum buy I haven't mastered posting links) sells the spoon individually so perhaps you should contact them. In fact, I might even have an extra so if you don't figure something out pm me your address and I can put one in the mail - not a big deal for me to be left with just one.
    Mag posted while I was checking to be sure I have a spoon. The straw idea is a good one, and you can experiment a bit with the amount to get it pink, but not use more than needed.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would call it more line 1/4 or 1/8 pea, it really is a small amount, a drinking straw might work, but make it a small one, not one of those jumbo sized ones like you get at Mc Donalds.
    30,426
    Not necessarily. The most common problem by far for the solution not to turn pink is the fact there is NO chlorine.
    Folks often think the test is no good but you have to have chlorine in your pool FIRST before the solution will turn to pink.
    Feb 2008
    Denton, TX
    5,061
    Not turning pink is uncommon and usually the reason for it is exactly what duraleigh has mentioned. However, if you know in your heart of hearts that you have FC in there and it isn't turning pink, a quick OTO chlorine test will confirm things. Although you won't know whether you have FC or CC with the OTO test, it is 100% reliable in letting you know that you either do or don't have chlorine in the water.
    May 2013
    Twin Lakes Wi
    9
    Re: k-2006 no spoon for reactant powder - FOUND IT, nm
    Thanks for the very quick replies, used the tip of a plastic knife and watched a you tube video by doublewide6.
    After I ran all 5 tests I went thru the kit and found it, it was laying on it's side between bottles (same color as kit so blended right in)
    Guess I just assumed it would be in the little spoon holder.
    Feb 2008
    Denton, TX
    5,061
    Re: k-2006 no spoon for reactant powder - Found it NM
    Glad you found it!
    357's Avatar
    May 2013
    SE Michigan
    15
    I realize the OP found his but for anyone who has lost theirs, maybe a coffee stir/straw cut as mentioned above would give a strong yet small scoop for a substitute.
    18' round Intex Ultra-Frame pool, 48" deep. Default "A" size filter with 1500 gph pump, w/2nd 780 gph pump. Softened well water used for fill.
