Results 1 to 9 of 9
Thread: Dogs and pools
    Jun 2013
    Southeast
    78
    Dogs and pools
    Any preparation before or after with regards to allowing your dog to enter the pool? My main concerns are pet drowning and E. coli.
    24x32 feet, In-ground, Saltwater, Gunite pool (under construction)
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Dogs and pools
    Much like with children drowning is more likely the less experience, with time they learn where to swim to find the stairs, and get more and more comfortable in the pool.
    kenandshari's Avatar
    Aug 2010
    Savannah, GA
    134
    Re: Dogs and pools
    It depends on the type of pool and the breed of dog. We have a fiberglass pool and have let our dog as well as a friends dogs swim. Our dog is short haired and didn't want to stay in. Our friends dogs (2) are longer haired breeds and enjoyed the water. Lessons learned: The dogs did not hurt the fiberglass. They will accidentally scratch you. The long hairs will somehow lose more fur in your water than they have on their bodies. It took about 3 filter cleanings the following week to get all of the fur out of our water and filters. I hope this helps you and best of luck.
    Ken & Shari
    Savannah, GA
    16' x 40' freeform fiberglass inground (Pacific model, mfg by Tallman Pools), 23k gal, 2" plumbing throughout, Intellichlor IC-40, Easy Touch controller, Intelliflow VS 3050 pump, Pentair Clean & Clear Plus Quad Cartridge filter. 4 Jandy deck jets (3/4" plumbing), Fiberstars color changing lighting, SR Smith salt friendly diving system, Interfab Wild Ride slide, Aquasol Solar Heat (5 panels 4'x12' DIY install automated with ET) RIP Nitro Wall Climber Mar 2011-Aug 2012, Nitro is survived by a Polaris 360.
    Rick H's Avatar
    Jan 2013
    Liverpool, NY
    45
    Re: Dogs and pools
    I have a black lab, who loves to swim in the pool, and as kenandshari said, the amount of fur that she loses is amazing!!! And yes, they WILL scratch you as they swim by... I also purchased some of those 'skimmer socks' that cover the skimmer basket. They work great, and catch ,most of the stuff that would most likely have made it to my filter. Well worth it in my experience, seems like they save the filter from the extra junk.
    Upstate/Central New York. Roman style IG fiberglass pool, 13X33, 8800 gallons, installed July 2012. Pentair cartridge filter, 1 hp Pentair single speed pump. Taylor K2006 Test kit. Went BBB route in spring of 2013, no problems, no regrets!!!!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Dogs and pools
    Knee-high nylon as a skimmer sock to catch fur before it overloads the filter
    Get in and show the dog where the steps are so it doesn't panic when it can't get out the first time.
    Feb 2008
    Denton, TX
    5,061
    Re: Dogs and pools
    Proper chlorination should take care of any bacteria that the dog could add to the mix. Also, we recommend that anyone with dogs who swim or drink the poolwater NOT add borates to their pool as there is potential for toxicity there.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Re: Dogs and pools
    I have an above ground pool with stairs, my dog swims daily. Sometimes I think we got the pool just for him. Just a quick training period and he knows that the stairs are home base. We occasionally need to say no every once in a while if he swims too close to the sides, but we really haven't had any concerns. Yes, a lot of hair will be floating in the pool while he is in, but I have found that the skimmer makes quick work of cleaning that up.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Re: Dogs and pools
    Quote Originally Posted by 257WbyMag
    That is definitely not 100% correct.
    My dog has the unique talent to do #2 while she swims and did it a couple of years ago.
    I posted on here and was told that chlorine will not kill all of the dangers of dog poop. Anyone interested in specifics can check my previous posts and read about it.
    I was fortunate and there were no issues but apparently it can be fairly dangerous in a worst case scenario.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Feb 2008
    Denton, TX
    5,061
    Re: Dogs and pools
    Quote Originally Posted by ship of fools
    Well, pooping in the pool is not typical canine swimming activity. Bacterial cysts that can be found in stool typically need higher chlorination, UV exposure (sunlight), and in some cases, filtration for removal.
