Thread: How long to wait to adjust ph after shock
    May 2013
    Jonesville, VA
    28
    My first shock process has went very well. I got rid of the CC's and what ever else was going on. OCLT test was good. Did not loose any chlorine overnight. Today my chlorine came back down to high normal of 7.5 and I tested the ph. It was 8.2. Do I need to wait to adjust it or go ahead with the acid?
    Intex 24'x52" Ultra Frame AG, 12,481 gal.,
    Krystal Clear Model 633t pump, 2,500 GPH, 1/2 HP
    Install 5-17-2013
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: How long to wait to adjust ph after shock
    Adjust now. FC is below 10 so it's accurate.
    accurate-ph-test-during-shock-levels-with-r-007-t61076.html
