Results 1 to 10 of 10
Thread: Salty taste.
    Salty taste.
    I had some people over this past week and a few of them says the water tastes a little salty but didn't think anything about it because they were all a little intoxicated. My wife had a friend of hers over yesterday afternoon and they said the same thing. I can taste it a little but not like what they described. My SWG says salt is at 3100-3200, it changes some days but has been around that since I last added salt 4 weeks ago. Is this normal? I have some salt test strips but I have never used them and from reading don't think they are very accurate.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Salty taste.
    I'd check it with the strips. Your cell could be reading incorrectly.
    Some people are more sensitive to the taste as well.
    Feb 2008
    Denton, TX
    5,061
    Re: Salty taste.
    Perfectly normal.
    "Your pool tastes a little salty, Kyle."
    A couple of responses would work.
    Response #1
    "Yes, I have a saltwater pool. There is salt in the water because of this."
    Response #2
    "Then quit peeing in my pool."
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Salty taste.
    Normal. Some people are just more sensitive.
    You dumped how many bags of salt in the pool? Of course it's salty!
    Salty taste.
    Ok thanks. That was my response " Well it is a salt water pool". I just wanted to check after 4 people said it tasted more salty than other salt water pools they have been in. I will check it with the strips to see how far they differ.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Re: Salty taste.
    No one ever says my pool taste salty unless I tell them it is a salt water pool. Then the questions start!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Salty taste.
    I have had salt levels over 4200 at times and no one ever complained of it tasting salty. But then maybe my friends are smart enough to not drink from the pool.
    chiefwej
    Sep 2009
    Greentown, IN
    914
    Re: Salty taste.
    You might do a test and see what your levels are.
    I do notice a saltiness to my pool and others don't often comment. I tend to agree that some are more sensitive to it than others.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2011
    Monmouth County, New Jersey
    81
    Re: Salty taste.
    I don't think I have ever had our water taste like salt. I don't drink it of course but I am sure I get splashed enough to notice if it were salty. I bet if those people didn't know it was a salt pool they wouldn't have noticed.
    Built in October 2011, 16 x 26 x 20 L shaped vinyl IG steel wall pool, Hayward DE pro grid verticle filter 4800 pool, Hayward two speed superpump, 120,000 BTU Pentair Ultra Temp Heat Pump, Aqua Rite Salt system, 8' wide walk out steps, 2 skimmers, 4 returns, 2 main drains, 500 watt underwater light, intermatic mechanical timer
    Feb 2008
    Denton, TX
    5,061
    Re: Salty taste.
    Even non SWCG pools can taste a little salty. Salt is left behind in the water as sodium hypochlorite is consumed in the water.
