Thread: help please with hayward main drain
    I realized yesterday that when I switch to the main drain on our pool my pressure goes to 0. We bought the house in march so I'm just learning. I got in today and in the drain there is a pipe to the side and a plug in the hole at the bottom of the drain. The drain is a Hayward 1048-c. I took two screws out of the cover 180 from each and inside the ring with 8 screws but I cannot get the cover off.
    I tried twisting and pulling. Wouldn't budge. Do I need to remove the 8 screws around the outer diameter or what.
    Thanks
    18000 gal partially buried doughboy ag
    225 lbs. Sand Filter
    Single stage powerpak II pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: help please with hayward main drain
    Quote Originally Posted by depogrig
    Thanks
    Stop. Can you see that the pipe to the side is open?
    That plug in the bottom is probably supposed to be there. Here's the manual. Check out the cross-section drawing.
    Study the valve that's above ground. Make sure you are looking at it correctly. Maybe it was open and now it's closed. With an anti-entrapment cover, you won't feel or see much suction at the drain. Make sure the valve says something like "Drain" on it, if it's labelled. Many drains are plumbed to the skimmer. That valve may go to something else.
    Pull the basket out of the skimmer and see if there are two holes. One should have suction. The other may be plugged, or there may also be a flying-saucer looking thing beneath the basket. Report back before you cause a leak!
    Thanks, the side pipe was open. I've had the hoses wrong since opening. i have a 3 way hayward valve just above the ground where the main drain comes up. the drain goes to one port, facing the ground, the skimmer goes to the port facing up and the outlet faces sideways. i had the skimmer hooked to the outlet port and the pump hooked to the skimmer port so the valve was not working the way the label on the valve said. switched those two and 15 psi on skimmer, main, or any combination. still would like to know if i only need to remove the two screws to remove the cover though. in case i ever need to.
    Richard320's Avatar
    Jan 2010
    19,031
    I haven't got a clue. Sorry. My cover was installed when I bought the place and I've had no reason to investigate.
