Results 1 to 7 of 7
Thread: Educate me PH & TA level
    Apr 2013
    South California
    69
    Those two give me headache.
    When PH is high (8.0), TA is high also (100), I add MA to lower the PH and TA. Then aerate to bring back the PH level. Everything is fine until few days they both PH and TA go up again. I repeat the procedure again, then again.
    What change them up so frequently?
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Re: Educate me PH & TA level
    There are many things that can change PH, but TA tends to be fairly stable unless you add a baking soda or a lot of acid. However, if you are adding water to the pool regularly to top off evaporation and there is high TA in your fill water, the TA in the pool would trend upwards.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Quote Originally Posted by hpdad
    Measure your tap water TA. I bet it's high. Mine was 220 last time I checked. It's such a common thing for me that I know how much acid to pour in for every inch of water I add.
    Apr 2013
    South California
    69
    Ah, it's tap water. Just measured and TA was 110. I top off water every few days. That is when the TA changes.
    Thanks experts. Much clearer now.
    Installed 4/29/13
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is not very high TA tap water...how much are you having to replace?
    Any chance you have been using much baking soda, washing soda or borax in the pool?
    Apr 2013
    South California
    69
    Quote Originally Posted by linen
    Not much, I top off about 1" to 2" on 15 ft pool every 3 to 4 days.
    Since put it up last month, the only adjustment was added MA and Chlorine.
    Installed 4/29/13
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That does not explain your TA rising issue...your TA would only go up by ~ 1ppm per week from your fill water (assuming about 3 inch water refill each week).
    That is a little higher rate of evaporation then at least I experience...but someone in your area might have a better idea, since evaporation rates are different due to RH, Temp, and wind differences.
