Results 1 to 8 of 8
Thread: PSI is lower than past years
    The PSI reads 10 on my gauge. I have always hovered around 14-15 in the past. I read the eyes and there placement might have something to do with this. Is that true? Another person thought it might need more sand in the filter. Does anyone have any ideas.
    Chris
    16' x 32' 20,000 gallon in ground pool
    Sand Filter
    Vinyl liner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: PSI is lower than past years
    Welcome to the forum.
    The most common cause of odd pressure readings is a bad gauge. Does yours go to zero when the pump is off?
    Pressure will go down if water can't get to the pump or if the pump is dirty. Check that you don't have any air in the pump strainer basket, then shut the pump off and stick your finger into the outlet of the strainer basket housing to see if you've got debris on the impeller.
    The gauge goes to zero when the pump is off. I checked the pump and cleaned out near the impellor. My skimmer basket is broken however. Could this have anything to do with it. I picked up a new one at a pool supply and it was too small. What about the eyes and how they're directed. Is that a possible reason for the low pressure?
    Sand Filter
    Vinyl liner
    22,553
    The direction of the eyeballs won't make a difference in the pressure but missing one or having larger will.
    A partially clogged impeller will also lower the pressure.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by cscafidi
    Are there parts of the basket missing? They may have gotten lodged in the impeller.
    Mark
    No the basket is just split no parts came off it.
    Sand Filter
    Vinyl liner
    SW Indiana
    9,199
    If the basket is broken to where it lets debris through, you could have something in the impeller.
    May 2013
    Deep East Texas
    79
    Could be a worn out o-ring on the defuser or another location on the suction side. I would think you would see a water leak or air in the pump basket. Start with the simple stuff first.
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
