Results 1 to 13 of 13
Thread: considering hard plumbing my system
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I am considering getting rid of the hoses and hard plumb my filter to the pool. Is the difficult to do?
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: considering hard plumbing my system
    Not if you are mildly handy.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Is it also possible to hard plumb the backflush so that I don't have to keep buying the hose every year?
    Installed May 2011
    BBB method
    Quote Originally Posted by Vette
    If you are less than mildly handy such as myself you can always cut multiple times. I hard plumbed in a few hours, be sure to use pvc schedule 40 L fittings instead of DWV (drain waste, curved elbows). I used the DWV curved fittings and later found out they're not rated as sched 40, no problems yet. But eventually I will be re plumbing.
    I recently thought about plumbing my waste pipe too, but trenching out would be a lot of work in my situation. I've had to blow off waste water 3 times so far this year. Most years it's around 5/year. Had I known I would want to trench a waste line out when we were trenching the gas line and electrical I would have definitely done it then. It could still be done now, but renting the trencher and all the work involved wouldn't pay off unless I look at it over 10+ years. I've used 2 PVC pipes to connect at the end of my backwash hose and go under the fence so it won't kink and explode. I unscrew these 2 pipes and put away when not in use.
    This is what I used:
    This is what should be used:
    Also -- instead of a PVC ball valve, use one that's made for a pool. Mine already feels like it will crack when I turn the knob, so I've been using a tennis ball in the skimmer to block it instead of closing the valve.
    Don't use this:
    Use this:
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jul 2012
    Chicago, IL
    356
    Consider using flexible PVC pipe as well. I just did so and the job was super easy. Got a good price and fast delivery from flexiblepvc.net
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    @Speedo.....where can I get a valve like the one you recommended?
    Installed May 2011
    BBB method
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Instead of buying those cheap back wash hoses go to a Granger's and buy a trash pump hose with the fittings you need. They cost the same and last for years.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    snooptodd's Avatar
    May 2012
    SW Ohio
    11
    That valve is called a diverter valve amazon link and can be found at just about any pool supply store. Another great thing about them is they come in multiport configurations.
    I have found that pvc unions HomeDepot link can be very handy.
    The first time I plumbed my AG I tried to make it look pretty, and didnt allow for drainage in the winter months. The first year I was able to keep the lines clear enough they didnt crack, the second year I wasnt so lucky( Im still picking pieces of pvc out of the yard.)
    27' AG, sand filter, Pentair 340203 Two-Speed 3/4-Horsepower, hard plumbed
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Those valves with the red handles, I have several of them and many have a very small crack in them, pretty disappointed in them.
    They may turn out to be trivial and not compromise performance, but they developed within the first season of use.
    Sorry I hadn't checked this thread in a few days. The diverter valve is from PoolSupplyWorld. As others have said, most places carry them. I believe the price is around $45.
    Aaron
    Quote Originally Posted by snooptodd
    Oops! Left that out, definitely use unions!
    Aaron
    just finished plumbing pool with pvc. the connections at the pool-wall have small drips. would using pipe tape or plumbers putty work to stop the drips?
    thank you
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Don't use the putty. Use thread sealant or tape. I like the sealant.
    Jeff
