Results 1 to 13 of 13
Thread: Salt Generator Acting up!! Hayward SwimPure Plus
    Jun 2013
    Verona, N.J.
    6
    Woke up to a Milky pool!! With coffee in hand I checked my Hayward Swimpure Plus generation box and noticed the power light and all the action lights were out. Additionally, the LED screen was reading 2700.
    I first checked the Diagnostic button and ran through the cycle. This revealed that the box and cell had the proper amps. 2nd I checked the main breaker to make sure there was no power issue. I disconnected the cell, inspected and cleaned it. There was a little debris caught in the front of the cell. I checked the flow switch which appeared to be fine. I also checked the length of the wires to check for breaks, cracks or bare wires. I have a Jandy Cartridge filter and took the time to clean the system to assure that it wasn't a flow or pressure issue.
    In Closing the panel box is reading the LCD diagnostics only, the five lights are still out. from top to bottom, power, generation, salt low, salt high, flow..
    AGP 25,000 Gallons, Using a Jandy (4) cartridge filter, powered by a Jandy 4 hp motor;
    Hayward Swim Pure Plus SWG
    Cleaned w/ 6 zone Auto/Bottom Jet Self Cleaning System
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Salt Generator Acting up!! Hayward SwimPure Plus
    Welcome to tfp, mikdagg
    Is it still producing chlorine? You can check it by comparing the chlorine level in the pool to the chlorine level coming out of the return. The return level should be a bit higher.
    Jun 2013
    Verona, N.J.
    6
    Sorry I should have read before posting. Hence the topic; READ before POSTING.. I have an IG pool, w/ 25K gallons of water, the Filter is a Jandy 4 cartridge, powered by a single stage Jandy 4 HP pump. Cleaning system is automatic from 5 zones that pop off bottom of floor. This is my 7th season, and the 3rd with my SWG. Hayward Swim Pure Plus, w/ T-Cell -15
    It is not producing Chlorine at this time..
    Hello!
    I have the exact same problem! Have you found a solution?
    Thanks for your help
    Simon
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by mikdagg
    I lost track that you responded. Have you resolved this?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by slessard
    Hello!
    Simon
    Welcome to tfp, slessard
    It is probably best for you to start your own topic. Make sure you read this: http://www.troublefreepool.com/pool-...efore_you_post
    Bosqueboy's Avatar
    Oct 2007
    Amherst, VA
    45
    I'm not sure if there is any real difference in the boards used in the two systems, but you might well profit (big time) by reading the series of posts titled "Aquarite Not generating - lights not on" in this section of the board. My guess is that the basic boards are the same and the solution to the problems with the plain vanilla AquaRite board may well save you big bucks.
    Bosqueboy in Virginia
    In-ground 20,000 gal vinyl Grecian, Hayward Star-Clear Plus C1200 cartridge filter, Hayward 3/4 HP Superpump, AquaRite salt water chlorine generator, Heat Siphon C575HP heat pump and Blue Diamond robotic cleaner.
    Finally I replaced the current limiter and it is back on track!
    It didn't looked busted but I measured it with an ohm meter and it was open...
    Thanks for your help!
    Jun 2013
    Verona, N.J.
    6
    I'm looking at my crystal clear pool as we speak.. I'm really glad for you.. Enjoy the nice water....
    Have the same problem. Can you tell me what part number you ordered and from where. I have a friend willing to try to fix for me but lives 120 miles away so I need to order the part before he comes into town. Didn't know if was the same one people are using for the Aqua Rite - looked on digikey and mouser but their are 500+ options (and I'm clueless). Thanks.
    Bosqueboy's Avatar
    Oct 2007
    Amherst, VA
    45
    Quote Originally Posted by scubaks
    The part you need is: Current Limiter Inrush 2 Ohm 25A part# 570-1062-ND from Digi-Key.
    I actually opened up the board and looked at the part number on the limitor after talking to my friend about 20 mins ago. The part corresponds to 570-1105-ND. in looking at 570-1062-ND it is SL32 2R025 rather than AS32 2R025. Other than a 4x cost difference any idea of the difference between AS and SL? Is it better to replace with what was recommended here as the factory installed one has had problems? Thanks so much.
    Bosqueboy's Avatar
    Oct 2007
    Amherst, VA
    45
    Electrically, the parts are pretty much the same. However, the 50-1105-ND can absorb more energy before it fails and the physical size is quite a bit different. It would appear that they have gone to a heavier part in hopes that it would survive longer. In any case, I would order the part that corresponds to what is currently in your unit.
