Results 1 to 11 of 11
Thread: Vacation algae
    Jul 2011
    West Monroe, La
    67
    Vacation algae
    Pool chemicals are normal, we have a little bit of green algae starting to form. Pump is running 24/7. 17k gallon AGP salt water ... Any thoughts or suggestions on how to stop this algae from growing/becoming worse??? All help is appreciated
    27'x54" Matrix Resin - 200lb Pentair sand filter - 1.5hp Pentair optiflow 2 speed pump - Aquatrol SWG - Gorilla Pad
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Vacation algae
    This would greatly help us figure out what's going on.
    If algae is starting to form, that doesn't sound normal.
    Jul 2011
    West Monroe, La
    67
    Re: Vacation algae
    FCC: 4.5
    TA: 70
    CYA: 70
    Salt: 3000 PPM
    Jul 2011
    West Monroe, La
    67
    Re: Vacation algae
    Ph: 8.2
    Aug 2009
    SF Bay Area (Lamorinda), CA
    122
    Re: Vacation algae
    http://www.troublefreepool.com/pool-...ya_chart_shock
    for CYA level of 70, chart recommends minimum FC of 5 so it sounds like your chlorine is low for the amount of CYA you have
    1950's-era 17K gallon formerly fiberglass, newly replastered IG rectangle (~15x30'),
    Hayward S244S Sand Filter with Franklin Electric 0.75 HP motor and WhisperFlo WFE-3 pump
    Clear ThermaTex bubble cover
    Manual vacuum
    Jul 2011
    West Monroe, La
    67
    Re: Vacation algae
    Thanks for all the posts
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Vacation algae
    Quote Originally Posted by swanny297
    Ph: 8.2
    Would also suggest lowering pH to around 7.2 first and then beginning the Shock Process since you have visible signs of algae. Once you begin the Shock Process, do not test for pH until you have passed all criteria and your FC drops below 10 ppm. You will also need to add bleach to reach the FC target needed for shocking as the SWG is not designed to crank out shock-level FC.
    Jul 2011
    West Monroe, La
    67
    Re: Vacation algae
    Thanks started shocking Sunday Am looking better just thankful it wasnt to bad going to vacuum and backwash tonight keeping FC around 24 any other levels I should be checking while in Shock mode? When it is clear do I allow the chlorine level to drop to the level on the CYA chart and than test all parameters again? I am thinking my FC dropped on vacation and maybe my guest wasn't measuring right.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Vacation algae
    Only check FC and CC while shocking. pH will be inaccurate, and nothing else will change.
    As for maintenance, do not let your FC level drop until you pass all three criteria. See Pool School for a refresher.
    Then, yes, test one more time, and use the chart.
    Jul 2011
    West Monroe, La
    67
    Re: Vacation algae
    I have passed 2 of the 3 my water is nice blue just not crystal clear is this because I have a sand filter? Is it safe to stop if I pass the overnight test again tomorrow if I am not perfectly clear or do I need to keep going? I just hate to keep adding bleach if the only reason it isn't clear is because of the sand filter I am maintaining FC levels though out the day as well.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Vacation algae
    Keep going. Is it worth the risk of turning green to stop a day or two early?
