Thread: New Pool - Chemical Questions
    Feb 2013
    Goodyear (Phoenix), AZ
    9
    Just finished having an IG 25,500 gal Pebble Sheen, Cartridge Filter pool put in the backyard, live in Phoenix AZ Temps are running around 95 degrees currently and new water has been in pool for 9 days. Builder gave me a Taylor 2006 test kit. Last night I tested water and results were
    FC 5
    PH 7.6
    TA 140
    CYA 30
    I was feeling unsure of my results so this morning I took a water sample to two different pools supply companies.
    Leslie gave me the following results
    FC 5
    PH 7.4
    TA 90
    CYA 30
    Local family owned store gave me these results
    FC 5
    PH 7.4
    TA 150
    CYA 20
    The builder told me that they wanted a CYA between 30 - 60 and wanted me to use the pucks and that it would rise in the next month. I love our pool builder they were great but our Super sort of poo-pooped the idea of liquid chlorine bleach. I've read pool school a bunch before purchasing the pool and during and I really feel the BBB method is the way to go, don't want to add extra stuff to the pool I don't need.
    At this point I'm thinking I just need to raise the CYA 20 - 30.
    I know the liquid stabilizer is more expensive but really don't feel like going through the hassle and waiting a week for the CYA to rise so my thought was that if I use the Pool Calculator and put in CYA of 25 and target 50 it says I need 221 oz of liquid stabilizer which is almost 2 gallons. So I was thinking about putting the 2 gallons in.
    Questions are, am I on the right track? How do I add it to the pool? How long until it is safe to swim after adding. Any other thoughts or advice anyone can give? I'm slightly freaking out but keep telling myself in a month I'll be in a much better position with all this. Thanks for any advice!
    25,500K gal, IG, Cartridge, Pebble, Pentair Intelliflow 1800rpm/3450rpm
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: New Pool - Chemical Questions
    Hi, welcome to TFP and congrats on the new pool!
    If you plan to continue using the pucks (I assume they are trichlor) do not raise the CYA. Trichlor pucks contain CYA and over the course of the swim season you will be adding a significant amount of CYA to the pool. Be sure to test the CYA every 2 weeks and stop using the pucks when you get close to 60 ppm.
    Most folks wait about an hour with the pump running after adding chemicals to swim.
    Love TFP? Become a
    TFP Supporter!
    30,419
    Welcome to the forum. A builder providing you a K-2006 really says something good about them. Using the pucks to get your CYA up is just fine as long as you manage it Like zea3 posts.......you already seem to know how.
    Your PB's Super needs to learn a bit more about pool water chemistry before he demeans liquid chlorine.....but he probably won't.
