Results 1 to 7 of 7
Thread: Creative way to rig a way to vacuum
    May 2013
    North East Ohio
    959
    Ok so this might be a stretch, but I will try to explain.
    I finally have my pumps running, with the exception of the skimmer/vacuum intake....so I have no way to simply just connect my vacuum hose (manual of course).
    My water is clear, except I have a large amount off dirt on the bottom just from construction, etc. My PB says it will be another week before that part is finished...
    Currently I have two main drains in the deep end on the wall that is all I have for water intake, of course my returns are all working. Does anyone have a creative way to somehow use one of my main drains to create a way to vacuum. I was thinking take a small bucket, cut a hole for the vacuum hose and then simply "COVER" the main drain with the bucket and I would get some suction.
    I could turn the second main drain off of course if that will help.
    Does anyone else have any ideas or ways to accomplish what I am trying to do. It is just going to be so hot later this week that my kid is begging for me to get the pool clean.
    Thanks in advance!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Creative way to rig a way to vacuum
    Why did the PB not put skimmers in the pool? To me that is a huge oversight.
    Mark
    May 2013
    North East Ohio
    959
    Ok sorry, I do have skimmers in the pool. It is just they are not functional yet. He claims he needs that line dry to finish the auto water leveler and then the bonding final touches, etc. So have skimmer, just not operational yet.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Ok, you had me worried there. Anyway, I wouldn't worry about vacuuming until the skimmers are running. Just get yourself a leaf rake to keep the leaves off the bottom in meantime.
    Mark
    May 2013
    North East Ohio
    959
    Yeah, I know I really don't need to worry, it is just my kid wants me to clean the bottom so he can swim without stirring up a bunch of dirt. I think I was only wishing that someone had a crazy idea that would help.
    mas985's Avatar
    Pleasanton, CA
    11,737
    If it is fine dirt, then you can use a pool brush to push it toward the main drain but be careful because leaves can easily clog a main drain so a leaf rake is much better for that.
    Mark
    May 2013
    North East Ohio
    959
    Yeah it is find dirt and I did use a leaf rake first, but I do have a few leaves.....so I've been watching for intake clogs and then shutting the pump to clear the leaves. Looks like I will just keep at this method until the PB gets things completely hooked up.
    Thanks!
