Thread: Contemplating adding an extra return to my intex
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    I have a 26' x 52" intex ultra frame pool. I have installed a widemouth skimmer and am planning to hard plumb it all.
    The skimmer and return are positioned in adjacent sections of the pool so they are fairly close together. What I'm thinking of doing when I hard plumb is to put in an additional return on the far side of the pool in order to increase circulation. Leaves sometimes get hung up along the water line on the far side of the pool.
    I'm not sure if the SandPro 75 pump/filter (3/4 hp) I have now will support this extra return so I came here to all the pool guru's I've come to know and respect.
    Is what I am proposing feasible or even desirable?
    Since the pool is large, would it behoove me to wait till I can upgrade to an a **better pump and larger filter?
    **I edited to read "better" pump instead of "in-ground" pump.**
    Thank you for any input.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Contemplating adding an extra return to my intex
    You could plumb it with valves, then if you do not get enough velocity with both open, you could close one, then upgrade the pump at your leisure.
    What size eyeball do you have on your current return?
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thank you Linen. That makes a lot of sense.
    Currently, I still have the original intex return. I also have the one that came packaged with the skimmer. When I do the hard plumb I figured to replace the intex return with a standard one. I did plan on having valves in for each intake and return involved.
    It's curious that with all the mods to these pools I haven't read about anyone doing this and was wondering if there was a reason/down side.
    Angie M.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Well I think it will work...it maybe that the really big intexs (like yours) haven't been around long and the smaller ones that have, do not have as much of a circulation problem.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Good point! When I get it done, I'll post back and let you know how it works. I appreciate you taking the time for discussion.
    Angie M.
