Thread: Need some help please
    May 2012
    Des Moines, Iowa
    14
    This is our first opening. Our pool was filled last fall but not until early November soit was ccovered and never used. We have it open now and am ready to start shocking. Here are my numbers...
    FC. 0
    CC. 0
    TC. 0
    TA. 60
    CH. 70
    CYA. didn't register at all, so less than 20
    PH. 8.2
    I reread pool school. I also went to the pool calculator.
    I have never even turned on our sand filter before, so I need to hook that up, then was thinking of hooking up our bug vacuum to it. I could see the bottom clearly 2 days ago. Now, I can't. I need to add water, about 1000 gallons (pool holds 9800) I can also release some and add new if it helps. My husband is at the store right now buying multiple bottles of bleach. If I'm going torrelease water, I want to do that before treating.
    Where would you start?
    Thanks in advance!
    13x25.5 Splash Titan3 AGP
    9800 Gallons Sand Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Need some help please
    Get the pool circulating first and make sure equipment is good to go. Lower PH to 7.2 before shocking. Bring CYa level to 30 before shocking at that level. Start shock PROCESS!
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    And take pictures to document your progress. It helps to keep from getting frustrated when you can see the progress.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Oct 2012
    Central Ohio
    180
    It'll take the CYA about a week to register on your test.(if you use granular)Just add it in a hanging sock in front of your return and assume it's at 30 for the time being.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
