Thread: Cloudy water due to calcium hypochlorite?
    I usually stick with BBB method. However, my pool was really green so I used calcium hypochlorite to kill the algae. That part worked great but now the water is cloudy. The guy at the pool store said it would make the water cloudy. Do I need to add a flocculant to combat the cloudy problem? If so, any recommendations on a particular brand? Thanks!
    JMK
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Cloudy water due to calcium hypochlorite?
    Quote Originally Posted by rudy
    If it's calcium cloudiness, it should disappear. More likely all that green stuff is now grey stuff and it will just take time to filter out.
    If, as you say, you use the BBB method, how did it turn green?
    Could you post some test results? You may have only fired the first shots in the war known as The Shock Process. You might want to re-read that article.
    You should post a complete set of water test results. From that we might be able to suggest something that will speed up the clearing process.
    pH was a little on the acidic side (6.8) and TA was 60 so I added a little baking soda this morning to adjust both of those issues. This is for an above ground 16x32 pool.
    It was green to start with because I only threw a net rather than a cover over it for the winter. I'm late getting it going for the season so .... green!
    JMK
    I added about 3 pounds of CYA but haven't tested yet. Haven't tested chlorine since adding cal-hypo. I've got to get more testing agents for chlorine today.
    JMK
    30,421
    Baking soda has little affect on pH. Adjust pH up with 20 mule team borax.
