Results 1 to 7 of 7
Thread: Well hello again, tested my friends pool water and.....
    Jun 2012
    Jackson, NJ
    105
    Here's what I got:
    FC 32.0
    CC 1.5
    ph 7.5
    TA 100
    CH 120
    CYA 45
    The pool has been green since they opened it and its been two weeks, the owner just dumped a bunch of powder shock and it has cleared mostly since yesterday.
    Water is still cloudy and has some greenish tint to it.
    What should I recommend for her to do next?
    I/G Concrete w/spa 29k Gallons (I think lol)
    DE
    Nature2 thingy disabled
    Polaris 280
    Aqualink RS4
    May 2013
    Boca Raton, FL USA
    21
    Re: Well hello again, tested my friends pool water and.....
    Well, that powdered shock more than likely contains CYA, so that level will go up as it dissolves and thus drive the required-FC shock level up, as well.
    Is this a vinyl-liner pool? If not, you'll want to get some calcium in the water up to recommended levels
    Aside from that, it sounds like they're on their way. Continue the shock process and the water should clear up soon, just stay on top of it. (and don't add any more powdered shock!)
    35x17 Inground concrete/plaster. 19,500 Gallons.
    Hayward H250 LP heater, Hayward 1.5HP pump, Hayward cartridge filter.
    Useful Stuff: Test Kit | CYA/Chlorine Levels | Pool Calculator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by AdrenalinPlease
    Here's what I got:
    FC 32.0
    CC 1.5
    ph 7.5
    TA 100
    CH 120
    CYA 45
    Recommend that she buy a couple cases of bleach and keep FC about 16 until (everyone repeat after me!) the water is clear, the CC is ,5 or less, and it loses less than 1ppm FC overnight. You need to read the label on that "shock" powder and if it's diclor or trichlor, take it away from her. Her CYA is high enough already. If it's Cal-hypo, she can continue to use it, but bleach is better because she won't have to monitor the CH climb with bleach. If this is a vinyl pool, there's a slim chance she's bleached her liner, and she should be careful not to overdose the pool again.
    Explain it thus: If the doctor prescribed antibiotics and said to take one in the morning and one in the evening for ten days, would you just eat all twenty at once?
    Encourage her to get her own test kit ASAP and to read Pool School and turning-your-green-swamp-back-into-a-sparkling-oasis-t4147.html
    May 2013
    Boca Raton, FL USA
    21
    Quote Originally Posted by Richard320
    ...and keep FC about 16 until (everyone repeat after me!) the water is clear, the CC is ,5 or less, and it loses less than 1ppm FC overnight...
    <chants>'the water is clear, the CC is ,5 or less, and it loses less than 1ppm FC overnight'</chants>
    Jun 2012
    Jackson, NJ
    105
    I know that chant as it has kept my pool amazing all of last season and is just the same this season, I love this place.
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    Her pool is vinyl liner.
    So her shock process should be 16ppm FC?
    DE
    Polaris 280
    Aqualink RS4
    Richard320's Avatar
    Jan 2010
    19,074
    Pool Calculator says 16. Pool School says 18 (by interpolation) Either will work.
