Results 1 to 13 of 13
Thread: HIGH ph SALT POOL/ Help lower
    Jun 2011
    South Shore - Massachusetts
    39
    Hi Folks,
    Opened last week, 4 yr old, 22000 salt water with vinyl liner, cartridge filter, got running and attempted to balance;
    Taylor test kit reflects-
    Chlorine - 8
    FC - 0
    TA- 60-80
    CYA - 80
    C.Hardness-- near zero
    **PH- off chart to read, red with hint of purple, estimating 10-11**
    Can you suggest what I might to to lower the PH into acceptable levels?? Last year ran steady high at about 7.8 all summer.
    Thanks
    Ed
    "Keyhole" 20 X 40, approx. 24,000 gals., Salt Water, vinyl liner, Goldline T-Cell 15 SWG, Aqua Plus Controls, Hayward 1 1/2 hp Super Pump, Hayward Gas Heater, Hayward 4 Cartridge Filter, Solid Safety Cover with Center mesh panels, AquaBot Remote Control Cleaner
    May 2013
    Boca Raton, FL USA
    21
    Re: HIGH ph SALT POOL/ Help lower
    Muriatic acid will do it. My local Home Depot carries it. See the pool calculator in my sig to determine how much to add. Do it in small doses so you don't overshoot your target.
    35x17 Inground concrete/plaster. 19,500 Gallons.
    Hayward H250 LP heater, Hayward 1.5HP pump, Hayward cartridge filter.
    Useful Stuff: Test Kit | CYA/Chlorine Levels | Pool Calculator
    30,426
    Once you lower your pH as tjf suggests, you desperately need to get some chlorine in your pool.
    read "The ABC's of Pool Water Chemistry" up in Pool School....an excellent place to start
    May 2013
    Boca Raton, FL USA
    21
    duraleigh,
    Why is his chlorine need 'desperate' ? (I'm asking, not challenging, as quotes tend to imply)
    CYA chart shows Min FC as 6 for his CYA, and Target FC of 9 -- he's at 8. What am I missing?
    Thx!
    I image that duraleigh is reacting to the line which says "FC - 0". FC is free chlorine, which is the kind of chlorine you want to have in the pool. The previous line that says "Chlorine - 8" is ambiguous, and might refer to TC or CC, either of which would indicate a problem.
    May 2013
    Boca Raton, FL USA
    21
    Ah, that's what I was overlooking. Duh. More coffee, please.
    Thx, Jason.
    Jun 2011
    39
    Hey guys, I'm sorry on that chlorine,
    I thought the same thing initially from your response saying to myself I thought my chlorine reading was right on,
    that chlorine reading was for the "good chlorine" the free chlorine, at a reading of 8
    not Combined Chlorine
    Thanks
    Ed
    Jun 2011
    39
    can you suggest what type of muriatic acid to buy from Home Depot? A particular strength or brand name? The calculator offers several choices and percentage strengths so I'm unsure of which to choose to do the calculations .
    Thanks
    Ed
    38,394
    The 31% is usually the better deal.
    Mar 2007
    San Rafael, CA USA
    12,082
    It's up to you and usually comes in two strengths. The full-strength Muriatic Acid is 31.45% Hydrochloric Acid. It's less to carry and is usually priced more economically, but it fumes so you need to be up-wind of it when pouring. There is also usually a half-strength version that is 15-16% Hydrochloric Acid and it doesn't fume as much, but it's not always half the price so may not be as economical. I don't think the brand really matters.
    Jun 2011
    39
    Hi Guys,
    I added about 3/4 gal of muriatic acid, brought ph down (i think) overnight to a light tannish/yellowish. Now I'm thinking I'm a bit low since it was similar mostly to the 7.2 yellow on the test glass. I added a little PH+ (sodium carbonate), maybe about 24 oz, ph phenol test now shows a light reddish color. Question is, test indicator goes from tannish yellow to a light purple to dark purple. Is my medium red indicating a move towards high ph again? Initially, I had a dark red when I was told ph was high, that's why I posted to the forum and then based on that added some muriatic acid. At this point dont know whether to add a little more ph+ or a little acid?? I'm unsure where the reddish color is on the scale. Thanks again for all the advice!! Much appreciated.
    May 2013
    Boca Raton, FL USA
    21
    Honestly, 7.2 is fine. It will drift up due to aeration, etc, over time.
    Did you use Pool Calculator to determine the amounts to add?
    Jun 2011
    39
    Well, it was 7.2 yesterday before I added the 1 1/2 lbs of PH+ sodium carbonate, now, as I said, it's a medium red??? I dont know if thats high again or low.
    I had assumed (perhaps foolishly dare I say it) that red was high ph, about 2 above the deep purple high of 7.8 on the tester, estimated at about an 11 PH, which is what orginally two days ago prompted me to add the muriatic acid, which got it to a tannish yellowish, close to the 7.2 on the tester. But now, after trying to bring it up a bit with the PH+, its a medium red, (not yellow low PH or purple high PH). Unsure at this point???
