Thread: I need a Jandy/Zodiac dual speed relay... does it exist?
    Sep 2012
    Orlando, FL
    27
    I have a Jandy Stealth 2.5hp, dual speed pump (Model: SHPM2.5) and a Jandy RS8 controller/power center on a new pool install. I'm supplying all of the equipment and the installer is just setting it up for me. The installer needs a dual speed relay to work with the rs8/power center. I ordered a "Jandy AquaLink RS 2-Speed Pool Pump Motor Relay Kit 6796" but I learned it's only rated for 2hp max pump (voltage and amperage is fine though). Looking through the zodiac catalog I don't see any other dual speed relays.
    Will the part I ordered be ok for a 2.5hp pump?
    Is there a different Jandy/Zodiac party I should have ordered?
    Thanks in advance
    ~12,000g IG pool w/ Spa and sun shelf, Jandy rs8 automation, Jandy CL340 filter, 2 Jandy Stealth pumps, Aquapure SWG, Ultrapure Ozone and Aquacal heat pump...
    Re: I need a Jandy/Zodiac dual speed relay... does it exist?
    That depends on the motor you have now. HP ratings are fairly arbitrary and often fudged by marketing types. Your pump might actually have a motor similar in size to a "standard" 2 HP motor, or it might be larger or smaller. The listed HP is only a hint. Take a look at the amp rating on the motor and also the SF (or service factor) listed on the motor spec plate to get a hint about what size the motor "really" is.
    If this is an above ground pool pump you are almost certainly fine. Above ground pumps always have listed HP ratings higher than reality. For an in-ground pump that is far less likely to be true, and you may need to hunt down a different relay.
    Sep 2012
    Orlando, FL
    27
    I completely forgot about the service factor. It wasn't listed on the motor but finding the replacement motor from A.O.Smith/ Centurion indicates that motor is actually a 2hp motor with a service factor of 1.3
    SO... I guess I'm in the clear then. Correct?
