Thread: Intex Krystal clear 633t upgrade options?
    tookiesmom07's Avatar
    May 2013
    Tennessee
    56
    We are currently leveling our backyard for an Intex 26 x 52. I am getting ahead of myself I know but would like some opinions/experience stories of the pump & filter that came with the pool when we bought it. It's a Krystal Clear model 633T. So we're going to have to buy a bunch of those filter cartridges since it says change that every two weeks. What I'd like to know is if this pump is ok or are there upgrades that we could consider. Maybe something in the sand filter line? I'm just curious about it.
    Intex Ultra-Frame 26x52 AGP (14,650 gal.)
    Intex Pump & Filter
    Jan 2013
    Aruba
    229
    Re: Intex Krystal clear 633t upgrade options?
    I recommend switching to the intex sand filter,it's more powerfull then those cartridge filter
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Jun 2012
    1 1/2 hours south of Chicago
    320
    We have the intex pool also we went out and bought the Krystl klear filter and we also run the salt water generator with it. It's in my signature but the pump will be changing my hubby some how fried the motor in the pump
    Tracy
    Vinyl 16X48 Intex pool with SWG
    Pool holds 5061 gallons of water Using Taylor k-2006 test kit
    Intex Krystal Clear 1,600 Gallon Sand Filter and Krystal Clear SWG
    Jan 2013
    Aruba
    229
    Does the 1600 sand filter work really good on that size of pool??
    Mine is 15x48" and i went i had i bought the 2650 gph to be sure i have the most water flow
    Thru wall skimmer,
    Hard plumbed
    Jun 2012
    Central Alabama
    55
    We have a 16 x 48 and quickly realized that the small cartridge filter that came with our pool was not going to cut it. We have the 2650 sand filter and love it!!
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
    Jan 2013
    Aruba
    229
    Actually the first year with the pool we used 2x1000gph and in the begining was it okay but once the whole pool became green i tried to vacuum the dead algea only to realize that everything was coming back in to the pool via the return, that's why this year i bouht the 2650
    Thru wall skimmer,
    Hard plumbed
