Thread: Cloudy Water thoughts...
    Things are running fine in my pool, the TF100 and BBB is so unbelievably simple and effective. I have a SWG, but the pool is too cold just yet... I should be turning it on this weekend as I am now consistently over 70deg. Having a SWG makes me grow less diligent! I am used to not having to add to keep FC where I want it. I test every 2-3 days, where I should be testing daily. This only makes any kind of difference at the first of the season when I cannot run the SWG due to low water temp.
    Hot sunny days brings the FC=0. The next day yields cloudy water - deep end pattern is distinctly washed out and you have to struggle to see it. Testing reveals FC=0, CC=0. TC=0. Completely my fault through laziness and habits formed by SWG. I bring the TC up to about 4 and in 2-3 days the water returns to crystal clear. Then a week or so later I get busy with work, and since we are not swimming due to cold water, I get lax again and it happens again. But clears up completely when I bring it back up for a couple of days.
    When I test I always have CC=0, and when FC=3-5 the water looks fantastic. I know the answer is "don't do that" (Dr, it hurts when I do this...), and there will be no issue when the SWG kicks on again.
    QUESTION: when all my levels are where I want them, the water is clear, when FC=0, it goes cloudy for a few days. Is this the norm? It there something slight living in my pool that is killed when I bring back the FC? My CC has always been 0. I can also pass the OCLT.
    It is not really a problem, since I do keep the levels where they should be, just a question about pre-season maintenance and an observation.
    Josh S
    20.8k gal vinyl kidney; 600sqft surf area, Hayward 1HP Super; 300Lb Sand Filter; Aqua-Rite/T-9; RainbowRay LEDs, Jandy Deck Jets; and a whole 'lotta sweat n time...
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Cloudy Water thoughts...
    Quote Originally Posted by shep377
    Yes, this is very likely what is happening.
    Smykowski's Avatar
    Sep 2011
    3,065
    Since your SWG is not on yet, you are temporarily running a manually chlorinated pool. Adust your min FC level accordingly until the SWG can do its thing. What is your CYA level?
