Thread: This may be a dumb question...
    Should the water be tested with the pump on or off?
    Does it matter?
    12K gal, IG pebble, 1HP Hayward cartridge filter C4020CP, waterfall, Hayward basic automatic vac.
    38,540
    Re: This may be a dumb question...
    Always run the pump for at least an hour before you test and an hour after you add any chemicals.
    Thank you!
    I just spent a week clearing up my pool and want to make sure that I test it properly to make sure I don't ever have to wake up to a green swamp again.
    This forum has been a life saver!
    Does it matter whether I run the pump at night? I currently run it for 5 hours between 11 p.m. and 4 a.m.
    38,540
    Does not really make a lot of difference when you run the pump. There are slight advantages running in the day, but not worth the extra cost if electricity is cheapest at night.
