Thread: Pentair Max E-Therm Heater Trouble Shooting
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    Helping a friend with their heater. Worked last year, this year it will not start.
    Are there common problems or issues with these heaters. Will be looking at it tomorrow.
    Thanks
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    May 2013
    Deep East Texas
    79
    Re: Pentair Max E-Therm Heater Trouble Shooting
    I have 5 Max e therm heaters. I have had issues with the following:
    - Broken ignighter
    - several worn out heat exchangers
    - Mother board problem keeping heat settings
    - pressure/flow switch issues
    - voltage problems
    - Gas flow issues
    But I still like these heaters and by now I really know how to work on them. They also have several warning lights indicators on pad and under motherboard. It would be wise to read up on those warning lights before doing any major work. The guys at pentair are on call and very helpful.
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Tell us more as to what the issue(s) are? These units can sometimes tell you whats wrong based upon LEDs on the underside of the dome top.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    Two issues;
    Took apart to find mouse nest and some nibbled wires at the ignition AND while working on the rest of the system- including bubbles in the Spa mode ......
    FOUND A 2" RUBBER Plug wedged into the return line.
    After discussion seems like husband had one sucked in last year, but forgot to tell anyone but his wife...... luckily was able to remove with a coat hanger. It came all the way from the spa drain.
    I know this would create a Service error and flow issue - as flow was low and I could not figure out why.
    So will finish cleaning out mouse nest and install ignightor today.
    Thanks
    ColorQ Pro
    TF-100
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    Ok I replaced the ignition and cleaned it out a bit.
    Still no fire. Tried turning circuit breaker off and resetting, but still no go.
    Service Heater Light is ON
    Did not see any LED's on top or underside of control panel after unscrewing. Will look at ignition control tomorrow as I just saw it was under a metal cover. Looks like there are LED;s in there.
    THINK A MOUSE may have made a winter home in it
    How do you clean out the combustion chamber and inside areas.
    Another tech before me replaced the thermostat, high low limit switch and some other switch.
    Or other ideas. Thanks
    ColorQ Pro
    TF-100
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Extremely unlikely anything go into the can where the burner is. It's a sealed chamber. Sounds like just a rodent issue and lots of times you end up chasing your tail on fixing it.
    Paul
