Thread: if FC drops below minimum, but only for a short while...
    Jul 2012
    Herndon, VA
    419
    if FC drops below minimum, but only for a short while, is it always necessary to bring it up to shock level if you have CC of 1?
    I'm a little late adding chlorine tonight....have a FC of 1.5, CYA of 30, and CC of @ 1.
    Do I really need to bring FC up to 12?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: if FC drops below minimum, but only for a short while...
    CC of 1 usually means your in need of the shocking process. You could bring it up to the upper normal range (6 ppm) and recheck in the morning before deciding if you need to go to shocking level....but if it was me I would probably get it up to 13 ppm and do a OCLT: http://www.troublefreepool.com/pool-...rnight_fc_test
    38,251
    That would be the safest ... at least elevate it some.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    If your cc hits 1, well, you know what to do. I would not trust water at a CC of 1. Kill it now.
    How is the weather up in VA? Post your COMPLETE test results so everyone can help you. Where are your current results obtained from?
    Good luck and A Happy Swim Season!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jul 2012
    Herndon, VA
    419
    I put in 3 quarts of 8.25 % last night, which should have brought it up to FC 6.8 from 1.5, according to the pool calculator.
    Just tested, and FC is 10.5, with CC less than .5.
    I'm not sure how the FC reading is possible....to go from 1.5 all the way up to around 10.5 on 3 quarts of 8.25% bleach.
    Weird....
    regardless, water is crystal clear, and CC is less than .5, so I'll go with it.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Did it recently rain? I registered CC of 1.5 during rain last night, but woke up with CC of 0 and water still crystal clear. I'm not gonna worry about it unless my FC use ramps up or the water starts getting cloudy.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
