Thread: How to clean solar blanket?
    He guys! My solar blanket get stuff stuck to it and then when I roll it up the dirt ends up in the pool or stays stuck on the blanket. I was wondering if there was an easy way of keeping the blanket clean? Like a clever trick someone could share? Last week I cleaned it by wiping it down little at a time as I was slowly rolling it up. That worked in a way but it was a pain, any ideas?
    Thanks.
    24 x 14 salt water inground pool
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How to clean solar blanket?
    I use the hose and push the dirt into the skimmer with it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by JohnT
    Ditto and with the pump running.
    Mark
