Thread: New pool -1st opening. Need help
    Feb 2010
    Central NJ
    53
    Hello all
    Im helping my brother open his new pool built in 2012. This is the first year opening the pool. We have removed all my plugs and gizmos. Tightened all the drain plugs in the pump and filter and primed the pump with water and tried to get it going. Pumps pulls hard for 5 seconds and then looses all pressure. Tried it again but only open the intakes value from the skimmer have way. We were able to get it running, but as soon as We open up the in take valve from the skimmer to 100%, We loose all pressure and have to start over. With the value open 50% We can keep,her running at 10 lbs pressure. I checked the impeller for obstructions and double checked all valves and jointsmfor leaks I'm fearful theres a leak under the new concrete patio however I had no problems last year
    Please help
    His info
    18000 gallon in ground pool
    Hayward de3620 filter
    SWCG
    1 skimmer 2 bottom drains 3 returns
    Rgds,
    Dominick (Inground Pool Newbie)
    650 sq/ft - 20k gallons
    Free-Form Gunite with Granite Ansylbrite Finish
    40 sq/ft 18' raised spa
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New pool -1st opening. Need help
    It sounds to me like the water level is too low or the weir is stuck closed. You're probably sucking the skimmer dry and it loses prime. One of you watch what happens in the skimmer while the other throws the switch.
