Thread: umbrella sleeve a little too big, causes umbrella to spin
    Aug 2010
    Charleston, South Carolina
    77
    We put a couple of umbrella sleeves in our new pool but for some reason they're not a snug fit. It's not a problem for our round umbrella since it's round, but our rectangular one on the tanning ledge slowly spins with the wind and ends up ****-eyed. I thought about getting some small rubber wedges and tapping them down there. Or maybe a rubber washer. Has anyone else experience this or found a solutions??
    THANKS.
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    May 2013
    Central Louisiana
    13
    Re: umbrella sleeve a little too big, causes umbrella to spi
    A washer might not do the trick- something like an umbrella in the wind can get a bit more power than a washer would be able to handle for any length of time. Any time I've run into a problem like this, whether it's construction, landscaping or IT work, I've always relied on wedges. I don't see why that wouldn't work here. The key will be that you can remove the wedges (and thus the umbrella) whenever needed.
    That's n00bvice, though. It's subject to older, wiser heads.
    18k Gallon rectangle IG concrete pool, Waterco S600 Sand Filter
    Current test kit: Taylor TF100
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I'd try making some wedges out of plastic cutting board material. A jigsaw and drill with a hole saw, you could make a nice one with a hole for your finger to pull it out with.
    What material is the sleeve on the inside?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Aug 2010
    77
    The sleeve is PVC. Here's a link.
    http://www.poolpartsonline.com/p-740-vo ... older.aspx
    It's got a cap that you can thread in when there's not umbrella in there. I wonder if I could modify the cap?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Okay so a wedge may damage the PVC. How about trying some wraps of duct tape?
    I don't really see a fool proof solution here.
    If you did the wedge idea, you'd want it to be inserted the same location every time, and possible removing a section of the threads, a cut down into the sleeve, would allow for the threaded cap to screw back on , vs pushing the wedge in and messing up the threads. A slot for the wedge in the umbrella would help too if it's wood, maybe even metal but I don't know how you'd cut it, maybe a 4" cutoff wheel on a grinder and plunge cut it. Ultimately it would act like a pin.
    18'x43' Sport Pool
