Thread: Replacing Sta-Rite pump with ____???
    I am looking to replace my old very loud inefficient pump with something else.
    Current pump:
    Sta-Rite JWPAS5F-24A
    HP - 1.5
    115V
    attached to sand filter:
    Sta-Rite - T-210WF
    44 GPM
    Pool is around 20,000 gallons.
    Any suggestions? Thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Replacing Sta-Rite pump with ____???
    Welcome to tfp, elett01
    Do you have any high volume water features (deck jets, waterfalls, etc.)?
    By the way, your filter is on the small size for your pool...not that I would replace it if you are not having trouble with it. For future reference, I believe it is 2.4 sq. ft and we would recommend a minimum 3.7 sq. ft. for your pool.
    Nope, no water features.
    It is actually only 2.18 sq ft. Should I consider replacing it someday?
    Two more things:
    1) it is above ground (not sure I said that before)
    2) do I have to replace the whole pump, or can I just get a new motor?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by elett01
    When you do need to replace it, I would get a bigger one.
    You can just replace the motor if the pump is in good shape (you will need to replace the seals too). This has to be confirmed, but I think this is the 2-speed motor you need: http://www.inyopools.com/Products/03500017074549.htm
    You could also buy a new 2-speed 1 hp Hayward Matrix or Pentair Dynamo.
