Thread: Deck cracking and separation from pool shell
    Noticed pool deck cracking, had the deck mudjack leveled. the gap did not come back together.. Can this be repaired by chasing the crack and back filling with grout, concrete, or polyurethane ?
    Re: Deck cracking and separation from pool shell
    I'm mostly concerned about sealing off the gap between the deck and the pool shell to prevent water intrusion... Any chance I can fix this similar to a driveway crack? It appears to be cosmetic and not structural.. But water getting behind the shell may cause some big problems...
    Close up of the deck separation...
    Apr 2013
    Sacramento, CA
    2,769
    It is difficult to tell from the photos but is you shell settling? Water does not appear to be level.
    I would figure that out first.
    The pool is 35 years old... Hope it would have settled by now but never can tell what was underneath it.. The water line does not appear even aross the entire pool relative to the tile line . I imagine settling did occur.. Te affected area also appears to have been repaired before.. I need a quick fix to stop the water from entering the crack... Caulk or grout? Ill address the cracks later
    30,414
    Caulk. Grout is not acceptable.
