Results 1 to 7 of 7
Thread: CYA readings
    Aug 2011
    Cochranville, PA
    228
    CYA readings
    When you add CYA to the pool I understand it takes up to a week to show up when testing. But is it present and doing its job when it does not show up or is the reading correct.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,102
    Re: CYA readings
    When its dissolved its working and protecting chlorine from the sun. It takes a few days for the test to accurately work, so on the safe side we suggest a week. At times I get the readings I was expecting a day after adding the stabilizer..... Other times it takes 3-4.
    If its dissolved its working....
    Aug 2011
    Cochranville, PA
    228
    Re: CYA readings
    Thanks its been 5 days and I thought it would be higher by now. Maybe I measured incorrectly. I'll give a few more days. The only reason I even questioned it was I lost a lot of chlorine yesterday and today. Very hot and sunny. Just over-reacting I guess.
    Jul 2011
    Eastern Ohio
    7,102
    Re: CYA readings
    How much is a lot?? Was there heavy pool use??
    Aug 2011
    Cochranville, PA
    228
    Re: CYA readings
    5ppm. I was in it for an hour. Giving it a good cleaning.
    Jul 2011
    Eastern Ohio
    7,102
    Re: CYA readings
    That does seem high....but if your heat was as bad as ours it's possible. When in doubt try the OCLT. Eliminate the sun and see if there's anything else consuming your chlorine.
    Aug 2011
    Cochranville, PA
    228
    Re: CYA readings
    The farmers are plowin the fields(a lot of dust). But not concerned have the whole weekend to keep an eye on things. Thanks
