Thread: which Hayward Filter do i have?
    Guest
    My sand filter circumference is 74" and I need to know if it is an S200 or 240 to purchase new springs, it is a leaky mess.
    Thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: which Hayward Filter do i have?
    Assuming that is the circumference of the filter shell and not the lip that bolts it together, then I would guess 74/pi=23.55, so I would think it is the S240.
    Guest
    I meant to order o-ring replacement. I actually measured the lip outside the bolts. I will re-measure the tank itself at its widest.
    38,275
    I also could not find a good set of dimensions to tell the difference between the 2.
