Results 1 to 13 of 13
Thread: How to stop using mineral cartidge in Zodiac Fusion Soft
    May 2013
    Kissimmee, FL
    5
    I have a brand new pool I just installed and I wanted an SWG. The pool builder installed a Zodiac Nature2 Fusion Soft which has a mineral cartridge with it. My daughters are all blond and it is turning their hair green. I have read countless articles on here about this and the use of minerals. My question is I have also seen people say that they have stopped using their mineral cartridge on this system and just used the SWG portion of it. I want to do this but I don't see a way to get rid of the mineral cartridge as it makes up the center part of the cover. How do I stop using the mineral cartridge and just use the SWG portion of the chlorinator?
    Thanks!
    Chris
    Pool: 16000 gallons inground plaster pool
    Filter: Cartridge
    Pump: 2 Speed 1.65 HP
    Pool Started: May 10th, 2013
    Other: Spa, Polaris 360 Automatic Cleaner, Ozonator, Nature2 1400 Fusion Soft SWG
    38,275
    Re: How to stop using mineral cartidge in Zodiac Fusion Soft
    Welcome to TFP!!!
    Can you post a picture of your equipment? Your description does not visualize like the pictures I see online of the system.
    I think you should be able to just take a cap off, remove the mineral pack, and then put the cap back on ... at least that is what Figure 1 looks like in this:
    http://www.zodiacpoolsystems.com/~/medi ... 44800.ashx
    May 2013
    Kissimmee, FL
    5
    On page 2, Figure one. See how the cap to the mineral cartridge is just a collar as they call it. The cartridge itself fills the hole in the middle of that collar.
    I will send a pic when I get the chance but that figure does show what I'm speaking of.
    Thanks for your quick reply!!
    Chris
    Filter: Cartridge
    38,275
    I think I see what you are saying ... that is a REALLY annoying design to force you to use the mineral pack. Maybe you can just cut the top part of the pack off ???
    May 2013
    Kissimmee, FL
    5
    Yeah. I'm trying to figure out a way to open that cartridge to get the bag out, although it doesn't appear to be a bag. I've been considering just leaving the cartridge in and not replacing it in 6 months when I'm supposed to but I'm nervous if it is ok to do that.
    Chris
    Filter: Cartridge
    Jun 2007
    New Jersey
    653
    If they are like the stand-alone cartridges--of which I am a past victim, they can rupture and release their little metal pellets into your return stream. Leaving a depleted cartridge in there would seem to augment the risk of this happening over time. It happened to me while I was traveling and the pellets got slurped up by the main drain and blown into the pump and filter. The staining of my plaster was intense.
    I would take a Dremel cutter to that thing and cut it off so that the only thing you keep is the top piece you need. Throw those nasty pellets in the trash.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    May 2013
    Kissimmee, FL
    5
    Yeah, that was what I was afraid of. I'll probably do what you say, break into the cartridge...remove the innards...and if I break the casing so be it. I'll just steal the top piece and screw that back in with the collar.
    I'll try it out and report back.
    Thanks!
    Chris
    Filter: Cartridge
    Oct 2011
    West Monroe, LA
    12
    What was the outcome of this thread? I am removing my Nature 2 Fusion as well and need to plug the opening the cartridge goes in. Trying to find a solution.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I'm not sure of the size, but what about using a mason jar lid. with the original screw top that came with the zodiac. I know the ball/mason jar lids come in different sizes.
    Jimmy Marinos's Avatar
    Jun 2016
    Visalia, CA
    1
    For my Fusion 2 system (SWG and Mineral Cartridge) I used a hacksaw to cut off the Fusion start-up mineral cartridge. Easy. The orange cap is still functional as I could easily cut below the cap part. After reading the many posts about basically how "useless" copper addition is and weighing the cost of replacement mineral cartridges, I did not see the point in keeping the cartridge. The bonus: the pressure dropped by 20% on the system! (It went from 10 psi to 8 psi.) Thanks TFP, for giving me the confidence to do this. The mineral system sounded like a great idea: silver ions and copper ions doing great things and all........ Sounded good until I looked at the cost of a replacement cartridge. Beware of the marketing gimmicks!
    18,000 gal., IG, plaster; built 7/2015; 1,200 gal. 8 ft dia. spa w/ spillover; Jandy WaterColor LED lights; Jandy 1 speed 1.0 HP Waterfall Pump; Jandy CV580 filter (4 cartridges @ 145 sq. ft. each), Jandy VS 2.0 HP pump; Fusion Soft SWCG; Aqualink Control; Jandy Pool and Spa Heater; Cleaner: "The PoolCleaner" 2X; City Water; Taylor K-2006C; SAVI Melody LED lights Jimmy Marinos
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Also the mineral cartridges can stain your pool and turn hair green.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    May 2013
    Kissimmee, FL
    5
    I was able to get into the cartridge and remove the bag. I kept the cover and just use that now.
    Chris
    Filter: Cartridge
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Old thread resurrected here, but I'm pretty sure my new Nature 2 (2 years ago) had a plastic lid in it when taken out of the box, just the top part to plug the hole - no need for a cartridge or to mutilate one. So thinking you might reach out to Zodiac if needed to see if there is just the lid or plug, whatever you want to call it.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
